How do I locate the freezer side glass heater elements? Do I remove the panel(s) inside the freezer compartment? The fan will get ice built up on the blades every 4-5 months and I have been removing the freezer panel and defrosting with a hairdryer. I have not seen the orange glow or heard the burning sound of the defroster in a long time so i am guessing the glass heater element is shot. Thank you in advance for your help or suggestions.
Okay, the heater elements were below the evap. behind the lower back panel inside the freezer compartment. The glass units look clear and the wire filaments look solid and intact. Does anyone know where the defrost timer and the thermo. are located...behind the rear panel on the refrigerator perhaps?? Thank you in advance for your help. Phil.
