My 3 year-old refrigerator (freezer on top) suddenly began freezing some of the food in the fridge portion. Not all food is frozen. I increased the temperature from 37 to 40 and more food has frozen since. I unplugged for approximately 10 seconds, but problem persists. Any ideas as to what could be causing problem and how I could go about fixing it?:confused:
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it opens and closes when you adjust the temp of fridge. Here's a diagram of the parts of your controls and dampers. http://c.searspartsdirect.com/lis_png/PLDM/K0503002-00002.png
Originally Posted by: woodchuckie The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it opens and closes when you adjust the temp of fridge. Here's a diagram of the parts of your controls and dampers. http://c.searspartsdirect.com/lis_png/PLDM/K0503002-00002.png Hi WoodChuckie, I can't make much sense of this schematic. Could you tell me which part number is the culprit? I have a Kenmore "Elite" Model# 106.74204401. Food is freezing in the refrigerator compartment. And there's a clicking noise up inside, from what would be the "ceiling" of the compartment. Thanks in advance, Chuck
