AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore Elite-water wont shut off, now wont drain
First problem was when the water would not shut off to go to next cycle. Then the real problem started when the washer would only agitate and not drain, spin etc. Help, I run a daycare and my washer is a major appliance in my house!!
The first thing I would do is check the lid switch. You have to remove the end caps and the screw on the each corner of the control panel. Pull the console forward and up and lay it on its back.Check how the air pressure hose is connected to the water level switch at the same time. - The part number for the lid switch is AP3020600 - The part number for the water level switch is AP3020315Gene.
Washer Repair
