I am looking for all parts necessary to permanently install the above mentioned portable dishwasher. I have received conflicting answers from various web sites about whether GE kit # WD35M34 will do the job or not, and also being that above kit does not include any hoses--do I need drain hose # 271907 (AP2039905) or some other part #. Also, do I need a new water feed line or not and what part # is that?
Rank: Administration
Groups: Administrators
Dear Willyd21, The part number WD35M34 is the correct kit for converting the model GSC3200J01WW from portable to built-in. Click on the below link providing a list of what is included along with instructions to install it. How to remove the washer cabinet.doc (25kb) downloaded 11 time(s).You will also need to purchase a drain hose part number AP2039905 along with a water supply kit part number AP3219877Both are approx. 6 feet in length. Anything longer is not recommend but should provide you with enough length as long as the dishwasher is installed next to the sink. Any additional parts needed for what plumbing you have in your kitchen can usually be purchased from your local plumbing and hardware store. If you have any additional questions please feel free to ask. Glad to help :)
