I have a Frigidaire side by side refrig thats freezing products on the refrigerator side. The damper was not operating properly. I replaced the damper motor, refrigerator control, and the adaptive defrost. Its still freezing products. The condenser coil is clean. Im stuck.... Can anybody suggest the next step?:confused:
Curt.
Does the damper now close all the way when you select a warmer temp in the fridge.
You may have an adjustable vent in the veg. or meat crisper . Is this the area which is freezing.
Does your compressor cycle on and off like it's supposed to.
Originally Posted by: woodchuckie ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does the damper now close all the way when you select a warmer temp in the fridge.
Does your compressor cycle on and off like it's supposed to. Its freezing the product on the 2nd shelf. The vgtable are not a problem. The damper was closing after replacing the parts, but the customer says its not closing now. This is a new damper with new controls, including the adaptive defrost board. The customer complained of an iced up evap whin the last year on two occasions. Thats why I replaced all componets. I asked the customer to set the freezer temp to a warmer setting to see if this would help. Thanks for the post. Curt
