awesomehd2
#1 Posted : Friday, December 7, 2007 1:32:50 PM(UTC)
awesomehd2
I am regularly getting puddles of water under my crisper drawers and don't know why, where it is coming from or what to do to stop it. Any ideas?
#2 Posted : Friday, December 7, 2007 3:18:09 PM(UTC)
Most likely the problem with your fridge is a clogged and/or frozen drain in the freezer.
Remove the back panel inside the freezer and check the drain under the evaporator coil. Using a hair dryer and a hot water, defrost and clean it.
- Here are the break down diagrams for the Frigidaire refrigerator Model FRT21LRGW2
