mjgeorge
#1 Posted : Wednesday, October 26, 2011 11:36:31 AM(UTC)
mjgeorge
I have a “Jenn-Air” Microwave (Model JMC9158BAW15), which sends out sparks during operation. These sparks have perforated a hole in the Cover-Ceiling (AP4221322) and have discolored the inside surface of the oven area just above the Cover-Ceiling. The tip of the Magnetron is charred and pitted. Can I replace this Magnetron and Cover-Ceiling? Will this repair the issue?
See this for a video example...
Microwave Magnetron Fail - YouTube
#2 Posted : Wednesday, October 26, 2011 1:10:22 PM(UTC)
Originally Posted by: mjgeorge Go to Quoted Post
...Can I replace this Magnetron and Cover-Ceiling? Will this repair the issue?...
It will fix it only if the body of the microwave (the tunnel) is not damaged. Otherwise it's time for a new microwave.
mjgeorge
#3 Posted : Wednesday, October 26, 2011 1:33:20 PM(UTC)
mjgeorge
Hi Gene, thanks for your reply.
I would like to get a better understanding of this; “body of the microwave (the tunnel) is not damaged.”
The waveguide tunnel is smooth but has some spotty discoloring. I have wiped this clean with alcohol. Just over the ceiling plate, on the oven surface, there is also some dark spotty discoloring. I have used soft scrub and alcohol to clean this off. This surface is now clean and smooth, but discolored.
The mica ceiling plate itself has a hole in it. I am replacing this. I figured I would switch our the Diode and Lamp while I’m at it. The Cap is good.
#4 Posted : Friday, October 28, 2011 3:31:02 PM(UTC)
Remove the magnetron and check the other end of this tunnel. If paint is damaged then it is not repairable.
mjgeorge
#5 Posted : Saturday, October 29, 2011 4:22:13 AM(UTC)
mjgeorge
Thanks Gene,
The waveguide tunnel the Mag connects to is metal, but I do not se that this is painted. Are you syaing there is a coating on the inside surface of this tunnel? The Microwave oven chaimber itself has an enamel paint on this, althogh discolored, it still seems intact.
I think I'm going to go through with this repair and try it out. I'll post the results. If it sparks, I'll get a new oven.
Guest (4)
