ronmonnin
#1 Posted : Wednesday, October 26, 2011 9:55:44 AM(UTC)
ronmonnin
1. Turn on to bake. The lock light flashes.
2. Turn on to clean. It set timer to clean. It heats up and then after a minute it shuts off and flashes f-9
#2 Posted : Wednesday, October 26, 2011 1:00:52 PM(UTC)
Check the door lock switch, wiring and lock assembly. If everything is good, replace the control board.
- The door lock assembly Part number: AP4097943
Guest (4)
stove top works, oven does not (Oven Repair (including Ranges and Cooktops))
by Neddster 12/14/2009 12:24:12 PM(UTC)
