ljv2008
#1 Posted : Friday, May 8, 2009 4:20:34 PM(UTC)
ljv2008
the dryerturns on but the timer does not turn and the is no heat what could be wrong
Drags1998
#2 Posted : Friday, May 8, 2009 4:28:08 PM(UTC)
Drags1998
Check the BREAKERS in the house, BOTH OF THEM!!!!
ljv2008
#3 Posted : Saturday, May 9, 2009 2:22:43 PM(UTC)
ljv2008
do you mean the fuses or do you mean if there tripped
Drags1998
#4 Posted : Saturday, May 9, 2009 2:41:14 PM(UTC)
Drags1998
see if they are tripped!!!:)
ljv2008
#5 Posted : Sunday, May 10, 2009 5:35:11 AM(UTC)
ljv2008
the breakers are not tripped could it be the timer
Drags1998
#6 Posted : Sunday, May 10, 2009 11:17:13 AM(UTC)
Drags1998
Possible, BUT unlikely, You may want to hire a PRO, If you just change the timer, and its NOT the problem, you have wasted your money!!!!
ljv2008
#7 Posted : Sunday, May 10, 2009 11:55:33 AM(UTC)
ljv2008
i turn the dryer on and tapped on the heater it flamed up for a second but turned off again, tapped it again and got the same results. Any more suggestions before i hire someone.
Drags1998
#8 Posted : Sunday, May 10, 2009 12:23:32 PM(UTC)
Drags1998
If you tap on the heater, and it comes on, Its either a funky acting thermostat OR the Heating element!!!!! Remove the heating element and look at it VERY CLOSELY!!! I think you will find a break in the element!!!! (when you tap on it the break closes up enough to heat for a second):)
ljv2008
#9 Posted : Wednesday, May 13, 2009 7:03:22 PM(UTC)
ljv2008
Thank you I found a break in the heating element.I appreciate the info and the money you saved me.
