appears to have a leak at the base of the tub, where the drive shaft goes in the middle, just a seal? any tips on removal/inspection? maybe even a part number I can use, this site doesn't list my model in their database. maybe something crosses over from another model?
thanks in advance
well I got the seal, now I have to figure out how to get the tub out, I have the top of the washer off, and I took the agitator off, I removed all the fasteners I could see on the drive shaft, but the tub won't come out, it looks rusty, I wonder if that's all that's holding it on or is there a snap ring or something that I can't see? any ideas????
You have an aluminum left hand nut holding the tub in place that likes to rust solid to the tub.I have one on a GE washer that I never got off!! First, you will need the special spanner wrench and a lot of pounding to get it off. Please Please inform us if you got it off and explain HOW. I tried penetrating oil and a cold chisel with no success. I think you have a plastic tub, so a blowtorch is a bad idea.
