garronc1
#1 Posted : 16 years ago
garronc1
When starting the wash cycle, the water comes out but the agitator starts at the same time. When the water stops flowing in, the agitator
stops also. Then it starts up for a few seconds and stops again. It
keeps repeating this start and stop cycle. Is this my timer or the control board?
Garron
#2 Posted : 16 years ago
Hi Garron,
Most likely the problem is a bad water level switch. Also I would check the wires inside the control panel.
- The part number for the water level switch is AP3019660
Kenmore Automatic Washer (Washer Repair)
by melissa66 14 years ago
by dojo55 14 years ago
