I have a Kitchen Aid Dishwasher that has a door that no longer supports itself and it falls open if one does not support it when opening. Do I need the link kit AP3775412 or something else perhaps?
Thanks,
Tim
Cannot say what needs replacing. Remove the kick plate and take a look. You may have to pull the unit out 6 inches or so to see what has broken or come loose. |
THIS FORUM IS DEAD!!!!!!! |
In case anyone is having a similar problem, it turns out the fix I needed included this:
AP3777680 (8535568) - Link
Hope it helps...
Tim
