One of the plastic waterlines under my fridge is leaking. There are a total of 3 lines visible. Two clear and one white that run side by side thru the bottom of the fridge and up the inside. One goes to the water filter and another to the ice maker. Do I have to replace the entire line or is there some type of "fix" for a leaking plastic waterline? It isn't leaking near the connection or anything....just in the center of the line. Any ideas? :)
the water line running into the refrigerator has a leak. How do I replace this line?
How do I change the water line running into the back of my kenmore refrigerator?
