I have a 6 year old thermador dual fuel that I have already replaced the coils twice in the main oven. Now the oven light flashes twice then the heating light flashes twice. The oven will not heat at all but the small oven works fine. Does anyone know what this code means, I have had two different repair companys out with two hugely different answers and prices.
Thanks, Laura
Hi Laura
Did you get your answer yet? we have the same problem.
We have the same problem, did you fix the problem? If so what was the problem, which part is required.
Thank You
Boba
