csbrill
#1 Posted : Thursday, May 7, 2009 6:21:29 AM(UTC)
csbrill
My side by side frig is cold on tbe bottom but won't cool. Cleaned coils and I don't know what to do next. Anyone have some ideas?
woodchuckie
#2 Posted : Thursday, May 7, 2009 2:54:30 PM(UTC)
woodchuckie
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. Is the freezer fan running. Hold the door switch in to check, as it cut off when the door is open. There is a flap you adjust with the fridge temp. control. Make sure it's open.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too. Take the back cover in the freezer to see the coils.
csbrill
#3 Posted : Friday, May 8, 2009 2:04:39 AM(UTC)
csbrill
thank you. My husband found the bad fan. Once he replaces it if it is still not working we'll try auto defrost.
