David917
#1 Posted : Wednesday, May 6, 2009 4:37:46 PM(UTC)
David917
I just received a new motor from appliancepartspros.com and the wiring diagram in the box does not match the motor that came in the box. Before I wire this new motor and "smoke test" it, I need to know if the wiring diagram is correct for the motor in the box. The GE motor number on the new motor is 5KH26JJ113S, the wiring diagram is for motor 5KH26JJ112S (a 2 instead of a 3 in the motor number). The diagram for the new motor shows the leads coming out of the motor as follows: Blue-5, Orange-4, Black-3, but the motor is actually wired Blue-8, Orange-7, Black-6. (I am referring to the terminal numbers on the motor)
sidfink43
#2 Posted : Thursday, May 7, 2009 6:41:34 AM(UTC)
sidfink43
Call on their chat line and talk with them about the problem. The people there are very helpful (and no I do notg work for them)
Good luck
