heidishandy
#1 Posted : Saturday, October 22, 2011 7:54:41 AM(UTC)
heidishandy
The single burner on the front right dual burner is not working
#2 Posted : Sunday, October 23, 2011 3:49:55 AM(UTC)
A model number may help others help you
Model Number Locator
heidishandy
#3 Posted : Sunday, October 23, 2011 9:55:04 AM(UTC)
heidishandy
Model #gr563LXSQ 1
#4 Posted : Sunday, October 23, 2011 11:00:33 AM(UTC)
Here are your parts.
Replacement parts for WHIRLPOOL GR563LXSQ1 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN | AppliancePartsPros.com
Here is a manual, it is the closest match I can get to your unit.
http://appliancedigest.c...elf-clean-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Odds are is that it is burned out.
You will have to remove it and check it with a meter. Should be around 5 ohms. Often you can see the break in the element.
Also note that the assembly includes a thermal protect (cut-off).
If it measures OK then probably the infinite switch is toast.
Be sure to unplug the unit when working on it.
File Attachment(s):
GR536.pdf (162kb) downloaded 8 time(s).
