I am trying to figure out which circuit panel is the problem so I can replace it. There is one circuit on the door right behind the control panel (part number GE 77527-1) there is also another circuit that is in the assembly that i guess takes the orders from control pad and gives it to the icemaker. It is part number GE 77526-7 (on the whirlpool sight appears to be part number AP4068159). Anyway, I just need to know which one to replace and I need to know if the whirlpool part is actually the same as the GE part I have).
Describe you problem in more detail.
The ice will start spitting out and will not stop until we take out the control panel/assembly - we just take out the whole thing. Sometimes water will also continually stream out.
