when it is time to agitate, washer humms then nothing then humms then nothing then humms again and usually quits leaving the washer full of water and a slight burning smell
It sounds like the motor is bad!!! or if you were REALLY LUCKY something is stuck in the water pump:)
doesnt the motor contro; the spinning too? is it hard to replace the motor?
Yes to the spinning, the motor runs 1 way to wash, The other way to spin.:)
okay. so definetly need a new motor. should i order one and replace it myself or just buy a new washer?
just to be clear. my washer works fine except when it comes time to agitate. then it does the humming and stops where it is at. if i move the timer to spin then it drains and spins thank you for your time and knowlege.:)
Without testing the motor, I'm not sure!!!! If it drains and spins correctly, It could also be the timer.:(
it does it on all modes. how to i test the motor?
