AppliancePartsPros.com
Appliance Repair Help
Washer Repair
water won't drain on some cycles but does on delicate cycle
The washing machine won't drain when on the regular or permanent cyclesbut continues through the cycle. It will drain when we put it on delicate
Most likely the problem with your washer is a bad timer. - The part number for the timer AP250045 - Here are the break down diagrams for the Maytag washer Model LAT8624AAEGene.
Washer Repair
