:( I have an Amana electric smooth top range. The range top works, however the clock and information center do not work, therefore the oven does not work. Can anyone help me?
Most likely the clock aka a control board has to be replaced. Unfortunately this part has been discontinued by the manufacturer and is no longer available.
Originally Posted by: Gene Most likely the clock aka a control board has to be replaced. Unfortunately this part has been discontinued by the manufacturer and is no longer available.
Gene. Thank you Gene for taking the time to reply back to me. I found the part on a website for $296. I don't even like the stove and don't want to put $300 into it!
