washer wont fill or agittate on any type of wash. Spin, no problem. Makes funny ticking noise on wash cycle.:confused:
Originally Posted by: mike blaha  washer wont fill or agittate on any type of wash. Spin, no problem. Makes funny ticking noise on wash cycle.:confused: Mike, Are you sure you have both, hot and cold water at the fill valve from the water faucets. Youre first step should be to check the water inlet(fill) valve Part number: AP3094541
Then the water level switch and hose, Part number: AP4567832
These are the two most likely situations, and where you want to start. :) :) :)
