My Washer Willn't Agitate Or Spin It Will Fill Up With Water And Drain. I Took Off The Belt From Motor To Check The Transmittion And It Was Fine Is There A Coupling That Can Be Bad?
What brand is your washer? The model number you provided does not come up.
Unfortunately, due to the model number you posted does not come up anywhere, I'm not able to help you.
Maybe somebody else on the forum could help you better.
If this is a belt drive,there will be no coupling. But if this washer is like the old Inglis then there will be two silenoid[magnet controls] most times the wires going to the silenoid will have a break in them. Pull on the WHITE AND YELLOW wires to see if there broken, if so repair.
My kenmore front loader model#41729042990 will not spin or agitate but will fill and drain. Control knob goes thru the entire cycle. Can some one help Thanks in advance Bob 200
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My Maytag trans motion went out in 3 years n it’s not covered on warranty. Wont buy another Maytag sgson
