I was getting a high pitched sound coming during the fill cycle and the upper dishes were not being cleaned. I have replaced the inlet solenoid and the sound has gone but the upper rack dishes are still not getting cleaned. I have disassembled the tubes leading to the arm and they are not blocked. I know the lower are is spraying water and the upper arm and impeller are not. What would be causing this problem?
