After depressing the cradle actuator to dispense water, crushed ice or cubed ice, the actuator will not return. Thus, the switch is still connected, and the ice or water dispenses continuously. I removed the rubber cover. I can pull the actuator back out and stop the dispenser. All dispensing actions work normally. Also, if I open the freezer door the dispenser stops.
I cannot see a spring or return mechanism in the cradle actuator (P/N AP2065704 ) Can you help? Thanks.
John
