I have located the problem and ordered the new dryer drum belt which has shredded. Question....how do I wrap the 'closed' belt around the wheel of the 'closed' Idler pulley??
Here is the belt diagram. I believe yours is the second from last.
Hook the idler assembly to the floor. Pull the wheel to the right. Slip the belt through the opening under the idler wheel and around the motor's pulley. Then slowly release the idler so it rides on the back side of the belt. |
THIS FORUM IS DEAD!!!!!!! |
