The upper rack on dishwasher does not go all way back to rear of washer. Rack extends such that door will not close. Often lifting rack will cure problem, often not. I noticed the rollers did not rotate on occassion. Is there some way to easily get rack to move all way in to allow shutting of door.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
