I Bought This Water Valve An On The Back The 2 Plastic Lines Were They Go In Won't Work Because The The Old One It Had Push In Sleeves An The New One Is Made To Push In An It Threads On. Do I Need To Go To Lowes To Get The Nut That Slips Over The Tubes Than It Screws On. They Said This Is The Right Part They Discontinued The Old One An The New One Is Made To Work. 1999 Ge Tfx20jr
Originally Posted by: wallyhitch I Bought This Water Valve An On The Back The 2 Plastic Lines Were They Go In Won't Work Because The The Old One It Had Push In Sleeves An The New One Is Made To Push In An It Threads On. Do I Need To Go To Lowes To Get The Nut That Slips Over The Tubes Than It Screws On. They Said This Is The Right Part They Discontinued The Old One An The New One Is Made To Work. 1999 Ge Tfx20jr HELP ME MAKE WORK
The New Vavles Are The Push In And The Old Vavles Are The Skew On. I'f You Fell You Can"t Install New Vavle. By One With Push In Vavles.
