After I select my desired drying cycle selection, it appears to work fine until it will shut off within 20-30 minutes leaving my clothes wet or damp. I have run all diagnostic tests and nothings shows up wrong. Please help:D
We need a litle more info.
I assume the problem is in the automatic cycles, is it?
Also, if you operate the dryer in the timed cycle and set it for about 1.25 hours will it dry the clothes?
Let us know and we can give you some guidance.
