rkuhn55
#1 Posted : Tuesday, December 4, 2007 11:46:23 AM(UTC)
rkuhn55
The glasses and cups in the top rack do not wash They seem to get wet but it appears no pressure is on the spinner Water level seem correct.
#2 Posted : Wednesday, December 5, 2007 11:40:59 AM(UTC)
Remove the pump cover and the inlet protector.
Check the chopper for clogs.
misterfixall
#3 Posted : Wednesday, December 5, 2007 6:51:34 PM(UTC)
misterfixall
check water level is correct .will not wash properly with low water level. if not could be problem with circulating pump motor . also check for debris in pump motor down to impellor
