:confused: Hello I have Whirlpool Model GBD307PRS01 double stainless oven with black display. Oven works fine but the display is very dim on the clock and you can't read the temperature setting at all. Can you tell me what part I need?
I really need help if someone knows the answer to my problem.. Thanks
Can someone PLEASSSSSSSSSEEE help me with this??
easye91471 wrote:
Whirlpool oven model GBD307PRS01. the display is very dim on the clock. Can you tell me what part I need?
That is usually controlled internally by circuits of the electronic control (clock unit) itself and will likely need to be replaced to correct the condition. :( LINK > Whirlpool GBD307PRS01 Electronic Control (no picture) Be prepared though, they're rarely cheap. :eek: JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
Dan- is this something an amatuer can replace???
