fred2117
#1 Posted : Thursday, April 30, 2009 6:08:06 PM(UTC)
fred2117
My gas dryer is not heating staying lit long enough? I had the back off and could see it will ignite for maybe a few mins. It does'nt light right away just whenever? Is this the coils or what
TechnicianBrian
#2 Posted : Thursday, April 30, 2009 7:32:06 PM(UTC)
TechnicianBrian
Most likely your coils need to be replaced as they have difficulty holding the valves open as they age. The usual symptom is ignition at the very beginning of a cycle, then nothing until the dryer is shut off and allowed to cool. If this is what you are experiencing, then the coils should do the trick.
fred2117
#3 Posted : Friday, May 1, 2009 3:33:17 AM(UTC)
fred2117
From what I've seen is it does'nt always light up right away. It came on after a few mins, then did the same thing after a while.
TechnicianBrian
#4 Posted : Friday, May 1, 2009 5:20:41 AM(UTC)
TechnicianBrian
You could be dealing with a gas problem, but odds have it that it is the coils (AP2150379) causing the problem. Given the age of your dryer, if they have never been changed, I would start there before looking at other items in the burner assembly.
