Glass shattered in door while tightening loose handle... what do I need to repair/replace. The stainless part of door is fine, but glass attached to inside of it (outermost sheet of glass in door) is shattered. Do I need AP3082505, "Outer Door Glass Assembly (Stainless Steel)"... which looks just like my door without the handle... OR :confused: ... can I get AP4365327, "Glass - door" (for about half the price)... which looks just like the glass attached to the inside of the metal ??? Any help would be appreciated...;) thanks
I would say you just need the glass and some foil tape but it would be best to contact the parts side of this site to make sure that this is the case. |
THIS FORUM IS DEAD!!!!!!! |
thanks for the quick response... will check with parts dept and update when we find out. thanks again denman.
