jaydg
#1 Posted : Monday, October 10, 2011 6:10:02 AM(UTC)
jaydg
I Have A Frigidaire Gallery Top Load Washer Model Fws645ghs0 That Does Not Spin Up To Speed On The Final Spin Cycle. Water Drains Out Properly. I Have Replaced The Belt But It Didn't Help. Doesn't Seem To Matter If It Is A Small Load Or A Large Load, Although It Happens Regularly With Small Loads, No Matter How Many Times I Rebalance The Load. Any Suggestions???
sidfink43
#2 Posted : Tuesday, October 11, 2011 5:45:05 PM(UTC)
sidfink43
Is sit spinning correctly after the wash cycle? If so, a timer problem is unlikely, but possible since it would not seem to have any mechanical problems.
jaydg
#3 Posted : Wednesday, October 12, 2011 6:05:25 AM(UTC)
jaydg
Sorry for the delay in getting back to you. Washer spins after wash cycle but I'm not sure if it is supposed to go as fast as the final spin. Everything seems to be working fine except for the fact that the clothes are still wet when machine stops. Water drains OK, spin is not as fast as it should be. Anything else that you can think of would be appreciated.
sidfink43
#4 Posted : Wednesday, October 12, 2011 7:03:00 AM(UTC)
sidfink43
Operate it with the front cover off, and check the drain pump and internal drain hoses for any obstruction. I have had several partial obstructions near the tub with these models.
jaydg
#5 Posted : Wednesday, October 12, 2011 7:20:59 AM(UTC)
jaydg
Thanks, I'll give that a try & let you know how I make out.
Guest (4)
