I've tested two stoves and I have the same issue with both.
A while back, I had a 26" Kenmore Mark II and one day the oven died. The range still worked, but the oven wouldn't heat. My wife and I opted to upgrade rather than repair so we just bought a used oven over the weekend. Well, we have the same issue with the newer one. There's power on all four range elements but nothing in the oven.
I found this odd and it's probably not the oven that's causing the issue. So I checked the outlet voltages and everything seems fine. Live-1 to Live-2 = 240V Live-1 to Neutral = 120V Live-2 to Neutral = 120V Live-1 to Ground = 120V Live-2 to Ground = 120V
For kicks, I checked the resistance in the oven elements and I was reading about 25 ohm's - which I believe is respectable.
Could this be a breaker issue? I checked the breaker (40amp) and intentionally tripped it to test and it trips just fine. I'm stumped because there's not much to this and I don't know what else to check.
Any ideas?
- Shaun
Hi Shaun,
What is the complete model number of the last range?
Gene. Hi Gene: I'm not 100% certain - I've looked all over the stove (front and back) for a model name/number and I can't find one. The dash board says Kenmore Easy Clean and it has the mechanical/analogue controls. I'm guessing it's a few years old. But like I said, I have a hunch that it's not oven related because it's the same exact problem that I had with the oven that I replaced it with. Do you think that a breaker could be at fault? Or is it just a coincidence?
By the way - I forgot to mention...
When I initially tested the outlet, I wasn't getting any voltage from the L1 or L2 when connected to the Neutral (white wire from wall). I took the outlet apart and noticed that the neutral had in fact come disconnected. So I reconnected it, assembled the outlet, retested it and then all voltages were OK. Despite the neutral being disconnected, I was still able to use the four ranges with no problems. With the Neutral being disconnected, would that have caused a wire to fry in the oven? I would assume no, and that it just wouldn't work properly.
If there is an electronic oven control then missing neutral could cause a problems. Have you looked for the model number on the frame behind the bottom drawer? I definitely need the model number and the wiring diagram.
Originally Posted by: Gene If there is an electronic oven control then missing neutral could cause a problems. Have you looked for the model number on the frame behind the bottom drawer? I definitely need the model number and the wiring diagram.
Gene. Yeah, here's the Model #: C880 6317590
Problem solved - There's just 1 dial for the oven. But three clock dials. One of them had a small font below the dial stating "Push for Oven". So I pressed it and the oven came on. Ugh... I'm so embarassed... LOL.
Thanks for the help.
You are welcome. I'm glad you were able to fix it and it was that simple.
