rheem unit, gas heat...a/c works great but suddenly heat will turn on..replaced thermostat, no help. called repair out they said to call gas service. Gas service said it was brain...replaced brain...heat works great but warmer weather is here and would like a/c to work without the heat turning on
Please give model number of the A/C-Heat Unit as well as the thermostat as lately mfg's. are not following the standard coolor code.
Red-power Yellow- air conditioning contactor White- heat relay Green- fan relay
this may be an issue with a setting on the differential on your t-stat if you have an auto option on your system selector switch not the fan it may be jumping between heating an cooling try switching it to just cooling or adjust your heat and cool temperture @ least 5 degrees apart. good luck
The OFF-AUTO-ON switch is to control the fan. It is a separate switch from OFF-HEAT-COOL. The "anticipators" function is to prevent overshoot of temperature. :)
