chris112
#1 Posted : Tuesday, April 28, 2009 4:23:43 PM(UTC)
chris112
:confused: Hi I have a Ewave over the range microwave that I recently re-installed and is now shutting off when running as a microwave. I did some construction in my kitchen and had to take the microwave down. Since that time each time I run the microwave I smell something burning and it seems to over heat and power down. All the lights and everything turn off and takes about 5/10min to turn back on. When I run the vent/fan and light on it can go for hours with no problem. When running the microwave it shuts down in 3/5 min. I have to assume its something blocked or clogged but I really have no idea where to start. Can anyone make some recommendations on what I can/should check.
Thanks!
alexnsacto
#2 Posted : Monday, January 18, 2010 7:15:11 PM(UTC)
alexnsacto
Ewave shuts off after a minute and half-power comes back on after about ten minutes but fan and light can stay on forevever -also defrosts with no problem -Can anyone help-Thanks
Can you or other member
#3 Posted : Tuesday, January 19, 2010 1:10:58 AM(UTC)
Your magnetron thermostat is cutting out on thermal overload. I would check the cooling fan near the magnetron, might be blocked.
