The water is not dispensing properly. It is only dripping out and I also noticed the ice cubes are hollow. It is still making ice just not solid cubes like before. I am going to assume there is some sort of water line problem somewhere and is not feeding correctly. Again, the water just drips out when you push the dispenser. Please help, this is so annoying and the wife is getting upset!!!!!! Thanks, all of your help is greatly appreciated.
Cut the water supply off under the sink or at the saddle valve whichever you have and disconnect the line going into the water inlet valve and take the mesh screen off and clean it and flush the water line by cutting it back on and letting it run into a container to get any sediment out then hook it back up and try again.
Thanks woodchuck, will give it a try!
I took all the water lines off and disconnected again, I couldnt find the mesh screen you were talking about though. The water dispenses fine now! I still need to find that mesh screen though to clean it....thanks, please continue to help me find it!
sorry, meant took the lines off and connected again, I let the main water line run for a bit like you said.
Originally Posted by: fowler12 I took all the water lines off and disconnected again, I couldnt find the mesh screen you were talking about though. The water dispenses fine now! I still need to find that mesh screen though to clean it....thanks, please continue to help me find it! The screen should be at the end of the water line coming into the water inlet valve. It may be inserted into the water inlet valve.
