em7777
#1 Posted : Monday, April 27, 2009 6:09:46 AM(UTC)
em7777
My Evenheat dryer is about six years old and it tumbles just fine but no heat sometimes. I couldn't get any heat from it last night but managed to get some out of it this morning after a few tries. The same thing happened the other day. It doesn't seem to make a difference whether it is set on timed dry or the sensor dry. From reading some other posts I understand that this could be a coil problem? Has anyone else had this same problem?
#2 Posted : Monday, April 27, 2009 5:45:16 PM(UTC)
Most common cause of an intermittent heat problems are a bad gas valve coils. Thats why I would replace them first.
- The part number for the coil kit is AP3094251
