billchamp
#1 Posted : Sunday, December 2, 2007 8:55:03 PM(UTC)
billchamp
Freezer section is freezing goods well. Only one cooling unit up in the freezer section dropping cold air down through conduits to refrig section.
One drops into a drain trough connected to drain pipe running to a drain tray underneath the fridge. Most of the cold air seems to be coming down through this conduit which is directly under the fan above in the freezer section.
The other conduit connects to a manual control for regulating temperature in the fridge but hardly any cool air seems to be coming down. The thermostat sensor is directly under this conduit covered by the manual control assembly.
Have removed the fan cover in the freezer and this gives some access to the cooling unit in the freezer. Seems ok here.
Have removed the manual cooling control unit which has improved the cooling a lot but except for overnight the fridge section still ranges from 10-15 degress C. It does come down to 2-4 degress C if left unopened overnight .
If you consider re-gassing might be needed could you help with an age for this fridge.
#2 Posted : Monday, December 3, 2007 2:44:29 PM(UTC)
The model number you provided is incorrect. Without the right model number I'm not able to give an accurate advise. Please, verify the model number and repost it.
