HELP! :confused: Freezer part of side by side does not get cold enough to freeze anymore. Unit stopped making ice cubes a few days ago. Ice cream turns to mush after a few hours. Other items, like frozen steaks, seem to stay frozen just fine. Not sure if unit is cooling, only not correctly, or if items frozen are frozen simply becuase of the insulation in the unit itself. As far as I know, fridge seems to be working fine.
I have unplugged unit for about 30 minutes and done following:
-vacuumed dust out of front panel (under doors), in condensor area, and inside of fan housing -replaced pinched water inlet tube in rear (for icemaker/water in door)- I think this was causing the icemaker issue
Fan is running as normal, rear condensor feels hot to the touch, but I couldn't find ANY coils in front or rear of unit that appear to be getting cold (should they)?
Any ideas as to what this could be caused by?
You should be able to access the evaporator coil behind the rear inside cover of the freezer compartment.. APPros has a link to your model with picture diagrams.. See if the evaporator coil is iced up and if so locate the defrost timer to manually turn the system into a defrost... Then see if the defrost heater heats up... Remove the ice buildup with a hair dryer and post back.. IF the coil is not iced up or is partially iced i.e. halfway or even less make note of this condition when posting...
