dalefurman123
#1 Posted : Tuesday, October 4, 2011 9:34:49 PM(UTC)
dalefurman123
how do I check the motor in this unit, I have ohm out the winding and can not fine any problems with it. I have check or replaced the door switch , speed control board and the timer and all seem to be good.
sidfink43
#2 Posted : Thursday, October 6, 2011 5:59:11 PM(UTC)
sidfink43
This manual will show you how to test it.
http://www.emaservicetips.com/p..._TumbleActionWashers.pdf
See the flow chart section. You test it by testing through the speed control unit.
