Wondering if my Profile Artica side-by-side is part of the motherboard recall. I can't find the list posted anywhere. Can someone tell me if mine is on the list?
The refigerator side wont stay above 30 deg......Freezing food. The temp controls are useless. The Freezer side works fine and stays around zero degrees. Any suggestions on what to look for?
Clay
The fridge temp controls moves a damper to adjust the amount of cold air coming from the freezer. It apparently is not moving the damper. I can't find diagram of your fridge and damper controls with the model number you gave but the controls etc should be behind the controls in the fridge.
