SCOTTWIEDRICH
#1 Posted : Sunday, October 2, 2011 3:35:18 PM(UTC)
SCOTTWIEDRICH
Hello. My kenmore dryer stopped working...even the interior light doesn't work. A service tech looked it over and everything tested fine, except a circuit on the motor was 'bad'. I replaced the motor as he suggested but it still does nothing. What is my next step?
#2 Posted : Monday, October 3, 2011 2:53:55 AM(UTC)
Since you mentioned the interior light I am assuming that it worked before this problem.
The same 120 volt power runs the light as runs the motor (L1 to Neutral).
So I would start by checking the power to the unit.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Next would be the door switch.
It turns the light on when the door is open but also provides power to the motor when the door is closed.
File Attachment(s):
82042101.pdf (955kb) downloaded 11 time(s).
