no led lights up and seems to be no power to motor, also where is the fuse located on this washer?:confused:
I cannot get that model number to come up. If this is a top load GE the fuse is in the wiring coming down the right side.
Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I cannot get that model number to come up. If this is a top load GE the fuse is in the wiring coming down the right side. Thanks for the info, I'll try that.
