rickado
#1 Posted : Saturday, April 25, 2009 7:08:40 AM(UTC)
rickado
HELP NO water coming when turned on but with dishwasher turned off and door closed water keeps speeping into washer, open door and water stops coming in. checked resitence on x1k scale and it is below One on the scale is this good or bad valve? What else can be the problem. Thanks rickado:confused:
#2 Posted : Saturday, April 25, 2009 11:36:09 AM(UTC)
Replacement parts for WHIRLPOOL DU980QPDB6 | AppliancePartsPros.com
Here is a tech sheet. Closest I could find is a B5 but it should be close.
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203379195.pdf
You definitely have a weird problem here.
Check if the valve is getting power when the unit off (120 volts)?
If it is not getting power and is leaking it needs replacing.
You may have another problem but I would start with the valve.
rickado
#3 Posted : Saturday, April 25, 2009 2:20:32 PM(UTC)
rickado
Thanks Denman I checked the valve no 120v with unit on or off and with door closed water keeps seeping in unit. will drain when put in drain cycle Thanks rickado
