Jonsc
#1 Posted : Friday, April 24, 2009 6:19:58 PM(UTC)
Jonsc
Fridge was leaking water, found a crack in the grommet and tube assembly.
Ordered one and just installed -- turned water back on tried to dispense water and water all over the floor found another tube with a crack in it, this tube comes out of the bottom or the fridge on the fridge side then runs along to the front.
1 - I can't tell if this tube is able to be replaced because I don't know where it's coming from
2- It does not appear on any of the diagrams
Please help
applianceman
#2 Posted : Friday, April 24, 2009 6:30:47 PM(UTC)
applianceman
That’s the tube going to your water reservoir #810 of the diagram of your fresh food section. You need to replace the water reservoir. Hope this helps!! Refrigerator repair guide
Jonsc
#3 Posted : Saturday, April 25, 2009 11:17:05 AM(UTC)
Jonsc
Thank you!!
Is there anything tricky about the way the tube is secured into the bottom of the fridge?
It doesn't look like it can just pull it out?
applianceman
#4 Posted : Saturday, April 25, 2009 6:14:10 PM(UTC)
applianceman
[FONT='Times New Roman']No most of the time it just pulls right out and the new one slide back in. It is secured with clips or clamp[FONT='Times New Roman']and there should be a coupling near the freezer door. [/FONT] One thing that may help is to cut the refrigerator off and tilt it over and sit it on a wood block so that you can work under it easily. [/FONT]
Jonsc
#5 Posted : Sunday, April 26, 2009 5:04:38 AM(UTC)
Jonsc
Thanks again.
I'll order the part and give it a shot.
