Jimmy
#1 Posted : Saturday, December 1, 2007 11:17:53 PM(UTC)
Jimmy
The machine will fill, aggitate but it won't drain. Don't know if it will spin because it has to drain first. I pulled the pump off and it is not clogged, and seems to be ok. Also when you advance the timer drain you dont hear anything like a pump trying to start.
#2 Posted : Sunday, December 2, 2007 9:15:40 PM(UTC)
Most likely the problem with your washer is a bad lid switch (#11 on the break down diagram).
- The part number for the lid switch AP3094500
