I am looking for new leveling legs for my Amana ACF4215AW oven. Everywhere I look the part number AP174482 or 31949001B is discountinued. I have found a similiar plastic leveling leg on other old appliances, but they are all either to large to fit or too small. There is a very similar part used on other ovens, but they are just a bit smaller and fit very loosely in the base of my oven. Does anyone know where I might find some of the part number AP174482 or 31949001B plastic leveling feet?
If you have one of them you could try taking it to a parts supplier and they may be able to match it visually if you get an experienced friendly counter person.
Only other thing I can think of is a jiggery pokery. Get the slightly smaller legs, put a washer and a nut on them, use this to adjust the level and then use another washer and nut on the top to lock them in place.
Could also get a larger set and have the shafts machined down to the proper size but this could be a pain trying to match the size and thread type.
Hopefully someone else will have a better solution. |
THIS FORUM IS DEAD!!!!!!! |
