Jibstretcher
#1 Posted : 16 years ago
Jibstretcher
We have a Viking Range #VGSC3064BSS that the ignitors have stopped working. All four burners are now out, and stopped working together at the same time. Seems to be a liquid issue. Question, is there a single control module that would short out and make all four stop working at the same time, and how hard to replace?
Johnwilson123
#2 Posted : 15 years ago
Johnwilson123
Top burner will not spark or ignite. I think it might be the spark module. The burners will spark and ignite for a couple of days if I disconnect all wires from the module and plug them back in. Can it be anything else other than the spark module?
Thanks,
peter11203
#3 Posted : 12 years ago
peter11203
Thanks,
It sounds like a bad conection, check the main power wires going to the spark box and make sure they are nice and tight. It sounds like it's making a burnt spot after a few days because the main power wire is not tight enough.
